585,762 active members*
4,216 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Morbidelli Author 430 s Help !!!
Results 1 to 9 of 9
    Lightbulb Morbidelli Author 430 s Help !!!
    Hello greetings. A relative has Morbidelli Author 430s and has been standing for more than 8 years. We want to make it work. does not have the software was lost. Can anybody help me. with manuals and software please.
    Jul 2018
    31
    Re: Morbidelli Author 430 s Help !!!
    Hello, can you post the machine serial number ? Its a metal plate on the structure of the machine.
    Regards
    Aug 2014
    232
    After 8 years the controller battery will probably have died, and the settings will be lost. I know from experience that getting support for these old machines is difficult.
    If I was doing it, I would upgrade it to a newer controller rather than waste time on something so old. Morbidelli used quality parts, hopefully it will be possible to use the existing drives, from Yaskawa or another quality brand.
    Jul 2018
    31
    Hello, it may be possible to get all the data if i get the machine serial number.
    Apr 2009
    4
    Quote Originally Posted by coc9 View Post
    Did you get all the data?
    I have similar machines. Did you succeed in recovering?
    Feb 2006
    19
    Hi Ambrosio
    Did you get the machine running. coc9 is correct. If you give us the machine serial number (usually on a silver plate on the side of the electrical cabinet) we can get the information for you
    Where is the machine?
    Regards,
    Loko
    Apr 2009
    4
    my serial is AL_007514 (Morbidelli Author 432S).
    I also have same problem.
    Attachment 476422
    Apr 2009
    4
    to loko
    I can't write you in private messages, some kind of errror.
    I am from Ukraine
    Jan 2022
    Thanks for your answer, I would like to know the resolution and detail of engraving on metal, cnc machine K6100A I want to work 8 hours a day, and my question is whether it is designed for such requirements, I hope your recommendation profecional.geometry dash
  1. Morbidelli Author 503
    By almakaas in forum CNC Machining Centers
    Last Post: 12-27-2020, 02:57 PM
  2. Need help Morbidelli Author 600
    By deni in forum CNC Machining Centers
    Last Post: 09-16-2020, 10:11 PM
  3. Morbidelli Author 427
    By elktw in forum CNC Machining Centers
    Last Post: 08-14-2015, 07:40 AM
  4. Morbidelli Author 636 top
    By mwatkinson in forum Commercial CNC Wood Routers
    Last Post: 05-11-2010, 10:52 PM
  5. morbidelli author 504
    By msahin2012 in forum Commercial CNC Wood Routers
    Last Post: 05-19-2009, 01:06 PM
