584,860 active members*
5,126 visitors online*
    Jul 2007
    165
    Feedrate after cycle pause
    Hi.
    Something I'm noticing on Mach3...
    Sometimes when I pause a job mid cycle, then resume, the feedrate used is much slower than it was before (maybe about 30% speed at a guess). It generally sorts itself out after a few movements (perhaps the next time a feedrate is defined in the GCode). I generally use GCode output from Vetric's Cut2D application. Generally I try and pause on an upwards Z movement when the spindle is moving away from the workpiece.
    I'm thinking perhaps the next X and Y movements are using the feedrate of the Z axis (which is much slower) but can't see why this would be. Running a program end to end with no pauses everything runs as it should.
    Does anyone have any thoughts on what could cause this? Is it a system setting somewhere in Mach3? I couldn't find anything...
    Thanks in advance
    Rich
    Re: Feedrate after cycle pause
    Are you using a parallel port, or motion controller? IF your using a motion controller, it could be causing the issue.
    When you resume from a pause (feedhold), the feedrate will be the same. Just look at the feedrate DRO on the screen before and after a pause, it should be the same, unless there's a change in the g-code.
    Feedrates in g-code are modal, meaning they stay in effect until there's a new feedrate command.
    Jul 2007
    165
    Thanks, I'll try and get some actual figures from the onscreen DROs. I have a parallel controller (actually I use 2 parallel ports so i also have MPG, buttons etc)
  1. Cycle pause in effect? What?
    By kentavv in forum Mach Software (ArtSoft software)
    Last Post: 09-05-2019, 09:57 PM
  2. Max Feedrate in a threading cycle
    By Pogojo in forum Fanuc
    Last Post: 10-10-2013, 07:22 PM
  3. Replies: 1
    Last Post: 09-08-2011, 04:08 AM
  4. Replies: 0
    Last Post: 09-07-2011, 10:45 PM
  5. 0i-MC feedrate is ignored after a tap cycle
    By jhartleyjr in forum Fanuc
    Last Post: 06-28-2009, 01:07 AM
