585,575 active members*
3,575 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > DAEWOO LYNX 210 CLAMP OD/ID QUESTION
    Oct 2020
    12
    Just starting to run my first Daewoo lathe, I have always run Haas. My machine has a Mitsubishi Meldas 64 control. I mounted a dead length 5c collet chuck on it and can't seem to get it to switch clamp OD to ID. The book says to switch parameter 6407 bit 6 to 0/1. I have done this and cant seem to get it to change the recognized clamping direction when I try to run the spindle. Keep getting spindle unclamped status when trying to run with drawtube pushed out which is what I need with dead length chuck. The parameter bit number is changing, I know they are from right to left starting with 0 and ending with 7, and the screen shows that clearly. Need help am I missing something else??? Thanks
    Oct 2020
    12
    Re: DAEWOO LYNX 210 CLAMP OD/ID QUESTION
    So I just dug into this a little deeper, the programming book shows the parameter information above, but the parameter book with my machines serial number on it says 6407 bit 6 is a high/low coolant parameter. I can't find one in the parameter bits in the parameter book that says ID/OD clamping. Hopefully someone has run one of these and is familar with it. Thanks
    Jul 2005
    380
    Is there a key switch on the control panel?
  1. Daewoo Lynx?
    By rpseguin in forum Daewoo/Doosan
    Last Post: 06-05-2019, 04:09 PM
  2. DAEWOO LYNX 210A
    By rcs60 in forum Daewoo/Doosan
    Last Post: 06-22-2018, 04:49 PM
  3. (HELP) DAEWOO LYNX 200
    By lildave26 in forum Daewoo/Doosan
    Last Post: 06-29-2011, 11:40 AM
  4. daewoo lynx 200 (help)
    Last Post: 03-09-2011, 04:47 AM
  5. DaeWoo Lynx 200 GL
    By fjd in forum Daewoo/Doosan
    Last Post: 10-30-2005, 03:43 AM
