586,011 active members*
5,085 visitors online*
Results 1 to 3 of 3
    Jun 2008
    36
    Zeroing issues with Avid Touchplate
    This could be less of a problem and more of a lack of knowledge on my part, but I am having troubles using the auto touchplate from Avid on my Pro 4896 (the square one with corners on one side). I am using Mach 4 - the one provided by Avid.
    My issue is that I am having parts milled in different locations than expected. Here are two basic questions that will probably drive me to a solution.
    1. Should the X and Y zero be on the edge of the bit or the center of the bit. Mine always seems to be the edge of the bit.
    2. Should I have to re-zero the X and Y between tool changes? It seems like with the orientation in question #1 I would have to. Going from a 1/2" to a 1/8" bit leaves the bit quite far from the corner of the work piece.
    I can get some pics if that helps...
    Thanks in advance.
    Shawn
    Jun 2008
    36
    Re: Zeroing issues with Avid Touchplate
    I think I figured out the bulk of my problem - when I was zeroing out, I had not been changing the tool diameter in the Mach 4 dialog that appears. Now, I think that Mach 4 changes the diameter based on the g-code that is loaded, but often times I was doing the zero before I loaded a new set of code. I am going to experiment a bit and see what happens
    35538
    1) Zero is to the center of the bit.
    2) No, you shouldn't.
    Unless you are using Cutter compensation (G41/G42), which I doubt, the tool diameter shouldn't have any affect on your cutting.
  1. AVID CNC ZEROING ISSUE
    By trojanman22 in forum Avid CNC
    Last Post: 08-11-2020, 05:19 PM
  2. Touchplate not working
    By goranmax in forum Mach Software (ArtSoft software)
    Last Post: 03-23-2017, 06:36 PM
  3. Zeroing Issues In Mach 3
    By onholder in forum Machines running Mach Software
    Last Post: 12-13-2015, 03:27 AM
  4. Touchplate
    By builtbypaul in forum LinuxCNC (formerly EMC2)
    Last Post: 06-21-2014, 03:16 PM
  5. deepgroove1 touchplate
    By taigfraeser in forum Benchtop Machines
    Last Post: 05-07-2010, 10:00 AM
