585,992 active members*
6,011 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 911 ram parity high on FANUC 0T mate
Results 1 to 10 of 10
    Aug 2007
    hi all can somebody give me solution for FANUC 0T mate?
    I have problem with my CNC turning with alarm 911 ram parity high, I already try to start up the machine but still cannot relsolve the problem.
    So please can somebody give me solution for my problem
    Aug 2007
    31
    Unhappy alarm 911 ram error
    hi , alarm 911 is a system alarm i beleive you will need to replace the master pcb or sent fanuc for repair, nakatome
    Jan 2007
    333
    Set the PWE parameter to 1, then switch machine off, then switch
    on the power while holding down the <DELET> key. All programs will
    be deleted.
    Post back here if this doesn't work.
    Sounds like you lost your parameters.
    When was the last time you changed your batteries?
    Power up holding in the "Reset" and "Delete" pushbuttons.
    Then reload your parameters
    Aug 2007
    To: bborb and cncdiag
    I already did that but still can't solve the prob;em because if i push anything in my keyboard it didnt respond anything, i think like nakatome said i need to change my master board or repair that master board, maybe anybody can give me master diagram fot FANUC that type??
    I want to try to repair it by my self i hope it will solve the problem that i have
    Dec 2007
    Hi, im new. i have the same problem than gunawan_tehnik and im sure that its the batteries.
    Can anybody explain how to relod the parameters?
    EDIT: I forget it, i have a Supermax turning machine with Fanuc 0T
    Nov 2006
    925
    E-stop in.
    Select MDI
    Press PARAM button to display SETTING 2 screen in PARAMETER
    Change PWE to 1 (you will get PS alarm 100
    Press PARAM button
    Enter parameters pressing INPUT after each one
    Press PARAM button to go to SETTING 2
    Change PWE back to 0
    Turn power off and back on again
    Mark.
    Oct 2007
    19
    alarm 911- Ram parity
    Off The machine and then Power on Machine with pressed DEL+Reset
    Im sure THe alarm 911 gone, after that select MDI and change PWE to 1
    and key in all data parameter, but first time you must key in setting Prm (necessary Prm 9000, see datasheet the machine) then off mc and again then key in all data parameter. god luck!
    Oct 2011
    I have a tool change problem with my Kitamura V40 with 6m control. Can 0 return the z axis manually to the tool change position, however machine rapids up to travel limit when returning to tool change position when running on program. Any help would be appreciated.
    Mar 2022
    5
    Re: 911 ram parity high on FANUC 0T mate
    we have okuma & howa act-4 0-TC Series Fanuc Controller. While switching on machine got system alarm 911 Ram Parity(HIGH). Further entering three alarms are shown as follows
    1) 100 - p/s alarm
    2) SERVO ALARM : X AXIS DGTL PARAM
    3) SERVO ALARM : Z AXIS DGTL PARAM.
    Dont have back up of this machine parameters. Please guide and support for running machine.
  1. Fanuc O-MD or Oi-mate?
    By Genguy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-19-2011, 10:15 AM
  2. Replies: 12
    Last Post: 09-26-2010, 06:37 PM
  3. fanuc 0 mate M
    By dasandy in forum Uncategorised MetalWorking Machines
    Last Post: 07-21-2010, 02:47 PM
  4. Replies: 2
    Last Post: 06-08-2007, 05:42 AM
  5. Fanuc 15 M Ram Parity Error(system Lable Lost)
    By SBAGHAEI in forum Servo Motors / Drives
    Last Post: 06-07-2007, 10:40 PM
