585,996 active members*
4,834 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > holes in a tube at 120 degrees
Results 1 to 6 of 6
    Nov 2012
    68
    I need help sketching an 8.625" dia tube with (3) 4.5" dia holes 4" from 1 end and 120 degrees apart.
    I have 1 hole drawn but can't figure out how to put the other 2 holes in at a specified degree from the 1st hole.
    Thanks for any help you can give me.
    I'm a beginner with cad/cam.
    Oct 2019
    8
    Re: holes in a tube at 120 degrees
    Which software? Autocad, Inventor, Fusion?
    Sent from my SM-G975U using Tapatalk
    Nov 2012
    68
    Fusion 360
    Oct 2019
    8
    My approach would be to
    1.sketch a circle on top plane
    2. create offset of that circle with whatever thickness your tubing is
    3. Extrude up the resulting ring to model the tube.
    4. Finish sketch
    5. Flip the tubing so it is vertical
    6. Create another sketch on the front plane
    7. Sketch a 4.5" circle about where you want it (you can fine tune location later with dimension tool)
    8. Extrude (cut) your hole through the tubing
    9. Create pattern (circular pattern)
    A. Select your hole outline
    B. Select Z axis as your axis that you want to revolve around
    Voilà, you're done! Click image for larger version.
Name:	3 holes in pipe.jpg
    Circular pattern using the feature (hole).
    Nov 2012
    68
    Thanks so much.
  1. Spindle 0 to 180 degrees
    By vinespo in forum Chinese Machines
    Last Post: 03-31-2016, 01:23 AM
  2. Replies: 8
    Last Post: 09-03-2014, 07:55 PM
  3. Tap holes in the end of aluminum tube, Tube will be provided
    By WRichards in forum North America RFQ's
    Last Post: 10-17-2012, 12:30 AM
  4. What is the best way to position holes on a tube.
    By voxelman in forum MetalWork Discussion
    Last Post: 04-15-2007, 06:02 PM
  5. How to weld plate to tube at 90 degrees?
    By coolman in forum Welding Brazing Soldering Sealing
    Last Post: 12-23-2004, 09:03 PM
