585,727 active members*
4,040 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper Motor Demagnetization
    Mar 2021
    Hope the community can help make some suggestions...
    We have a small device using a 8mm diameter micro stepper motor out in the field, and some have come back demagnetized. I'm under the impression that demagnetization can happen if a stepper is disassembled (this is not the case for us), or if there is an over current (which we need to test for), or if there the motor is subjected to a large magnetic field.
    Unfortunately, we don't have a good sense of scale, and most stepper motor advice comes from people with experience with much larger magnet motors. Are smaller motors more susceptible to demagnetization, and why? Looking for root causes of the failures.
    Are there other possible sources of failure?
    Apr 2004
    5734
    Re: Stepper Motor Demagnetization
    What "field" are you sending this device into? Is there a MRI machine in it? A tokamak? If not, it's probably overcurrent: see this article for hints: https://www.motiongoo.com/article/re...s-of-magnetism
    Andrew Werby
    Website
    Mar 2021
    When I wrote field, I meant just out in current use - not magnetic field. Drive systems are housed in a small plastic housing, and the device is handheld/battery powered and runs very slowly (like steps per minute).
    Sorry for the confusion.
    I did see that article thanks. What we don't understand his how much overcurrent, or how much magnetic field or how much heat would affect the magnets. Since this is a small motor, I would assume it's more sensitive to current and magnetic field - but how much would be needed to demagnetize?
    24220
    8mm, that is an extremely small motor, I have never had experience with that small a motor, but if this is a production device, I would think some empirical testing would be advisable, with due consideration to the environment they are being used in.
    Al.
    Albert E.
    Nov 2008
    110
    Magnets dont like heat - neodymium magnets can permanently loose part "power" if exposed to temperatures over 80 Celsius.
    See: https://www.supermagnete.de/eng/faq/...nets-withstand
    Sent from my SM-N950F using Tapatalk
  1. Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
    By muldoon22 in forum Stepper Motors / Drives
    Last Post: 12-31-2016, 07:26 AM
  2. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  3. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
