585,759 active members*
4,015 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > HiCell 23 Turret Not Indexing!
Results 1 to 2 of 2
    Jan 2017
    13
    Hello!
    I have a CA23 HiCell 23 Lathe, and the turret will not index in Program or MDI mode!
    The turret will index just fine in manual mode, however it will not move via program. It will get to the Txxyy00 code, and eventually timeout.
    Has anyone ran into this issue before?
    Thank you,
    Casey
    Aug 2011
    15
    Re: HiCell 23 Turret Not Indexing!
    normally some sort of door interlock fault, because turret will not index in auto mode if door is not closed
  1. Mori Seiki SL-0B turret not indexing (need turret zero)
    By pherolhh in forum Mori Seiki lathes
    Last Post: 07-20-2020, 01:50 AM
  2. Turret indexing
    By rishirocks001rk in forum Turning
    Last Post: 04-28-2020, 02:45 AM
  3. Fanuc turret indexing
    By Aylmer in forum Complaints and Praise Discussions
    Last Post: 01-30-2020, 08:22 AM
  4. NZ Turret Indexing
    By zooloader in forum Mori Seiki lathes
    Last Post: 04-18-2012, 05:55 AM
  5. Turret Not Indexing
    By rajesh_1355 in forum Fanuc
    Last Post: 02-24-2007, 06:25 PM
