585,973 active members*
4,041 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Peck drilling larger diameter holes on smaller CNC.
    Jan 2021
    19
    Hi Gent and Gentents!
    I'm newer to machining and I'm trying to accurately ream a .407 hole in aluminum about 2.3" deep. I have an LMS x2 mini mill converted to cnc that although has an upgraded motor, still struggles with a 9.7mm drill bit. I was wondering if I could spot drill, drill a 1/4" hole, then use the 9.7 drill. Would this still make an accurate hole? I need the location to be within .0005 (which the machine is capable of). Any input would be awesome! Thanks.
    -Will
    1224
    Re: Peck drilling larger diameter holes on smaller CNC.
    Try it on a piece of scrap?Doesn't appear to be an easy task and it presumes the drill bit is exactly what it claims to be.Do you have a small boring head?Again,a test cut would be wise.
  1. Peck drilling lots of clean holes in 3/4" plywood?
    By jasonwebb in forum Uncategorised WoodWorking Machines
    Last Post: 09-02-2017, 11:54 AM
  2. Drilling large diameter holes with a brace and bit
    By RichardDeptris in forum MetalWork Discussion
    Last Post: 09-01-2016, 05:42 PM
  3. Peck drilling - the 3 times diameter rule
    By maker4444 in forum MetalWork Discussion
    Last Post: 08-04-2016, 09:40 PM
  4. Replies: 0
    Last Post: 12-26-2013, 08:00 PM
  5. Help! Drilling small 0.02 inch diameter holes for vacuum molds
    By pohon88 in forum Vacuum forming, Thermoforming etc
    Last Post: 04-15-2012, 04:24 PM
