585,700 active members*
4,408 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > how to create gcode for this kind of work?
    Mar 2019
    18
    https://youtu.be/-di-NMFy5iI
    as in video, it's 3 axis rotary milling (spindle) machine, 1 rotary and 2 linear axis with a spindle. i couldn't see that option in rhinocam, there is 4 axis or 3 axis lathe without spindle.
    Dec 2003
    24220
    Re: how to create gcode for this kind of work?
    Requires an encoder on the spindle, or rather than turn the spindle into a servo, often the spindle motor is turned off and a separate servo takes over and gears the Z axis off of this spindle motor encoder.
    The spindle then becomes a C axis
    Albert E.
    Mar 2019
    18
    i don't see a reason for an encoder or servo instead of spindle, why you think that?
    and do you think it's not 3 axis?
    Feb 2010
    4
    I have the same issue, if you use Madcam you can do it... I'm still fighting to do it on Rhinocam
  1. Replies: 3
    Last Post: 04-22-2020, 05:09 PM
  2. Create NEW gcode file in PathPilot
    By vmax549 in forum Tormach PathPilot™
    Last Post: 07-23-2019, 02:20 PM
  3. Linux user ? Quesiton about create gcode for PathPilot
    By BlueBird1337 in forum Tormach Personal CNC Mill
    Last Post: 09-03-2017, 12:32 PM
  4. Replies: 3
    Last Post: 12-22-2010, 07:57 AM
