586,000 active members*
5,067 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Home built CNC Mill what conduit did you use for limit sensors & stepper motors
    Mar 2018
    13
    I'm in the middle of a CNC conversion to my Seig x2d mill and I'm trying to decide what cable conduits to use for the wires that will flex with axis movement. The stepper motor cable shielded but the limit/home sensors are not. I have access to plastic split loom and ends. Cheap but I'm concerned about metal chips from the mill falling into the inside of the conduit. I also have some 1/4 inch ID flexible stainless steel conduit. With a little drilling I can make it work with the 4 conductor aircraft connectors that I bought for the project. On the plus side it is tight so I wouldn't expect problems with metal chips getting inside. While I was proving the connectors could be modified to accept the metal conduit I noticed that the cut end of the conduit has some sharp edges. I think I can file them down and will probably be ok.
    What type of wire conduit has anyone else used on a cnc mill build? I'm interested in what worked and what didn't.
    Aug 2016
    132
    Re: Home built CNC Mill what conduit did you use for limit sensors & stepper motors
    Non-split flexible plastic conduit has worked fine for me on my PM25. I started using it since the Robodrills I worked on use it too, with no issues.
    Mar 2018
    13
    sounds good, where to you buy it? I looked on Amazon and all they seem to have in the 1/4 inch size I'm interested in is split.
    Aug 2016
    132
    I'm not sure if it goes down to 1/4". I've seen down to 1/2".
    https://www.amazon.com/Dorman-86665-...120815&sr=8-15
    Mar 2018
    13
    I finally found some by using the term non-slit conduit. I got the 1/4" size I was looking for. thanks.
  1. Using Hall Effect sensors as limit/home switches
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 07-26-2021, 06:59 AM
  2. Stepper motors with built in PS versus ones without
    By MajorTendonitis in forum Stepper Motors / Drives
    Last Post: 04-04-2017, 12:04 AM
  3. X3 Mill Built Home Robot
    By ImagineRobots in forum X3/SX3/G0619/G0463
    Last Post: 09-25-2012, 01:59 AM
  4. Home built CNC mill #2
    By jimglass in forum Uncategorised MetalWorking Machines
    Last Post: 04-03-2008, 10:29 PM
  5. Home Built Benchtop Mill
    By dcprecision in forum Benchtop Machines
    Last Post: 08-30-2006, 05:10 PM
