585,982 active members*
4,667 visitors online*
Results 1 to 2 of 2
    Mar 2021
    downgrade laser tube
    Hello everyone,
    I currently own a RECI W6 (130W) with which I cut 8mm HDF panels at 26% power (11,5mA) at 10mm/s.
    Given the obvious oversizing for my use, I would like to purchase a cheaper spare tube with lower wattage.
    In your experience, with a RECI T2 (90W) would I be able to perform the same process without problems? More or less, with what power / speed parameters?
    Thanks in advance.
    (Sorry for my english. Thanks to google translate.)
    Mar 2021
    Re: downgrade laser tube
    Can nobody tell me if with a 90w laser it is possible to cut 8mm HDF or MDF easily and the speed / power parameters?
    Thank you!
  1. As a Laser Tube Manufacturer, How We Test Laser Tube before Shipment
    By SPT-Laser in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-12-2017, 08:12 AM
  2. Need to downgrade Mach3 to earlier version. How?
    By cnc1000 in forum Mach Mill
    Last Post: 12-01-2015, 02:56 AM
  3. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  4. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
