585,917 active members*
3,537 visitors online*
    Jan 2007
    311
    Delta 1000 Rapid override
    Helping someone out with a Delta 1000 (2005-ish) control on a lathe.
    We don't have a manual so kind of wandering in the dark for settings
    The rapid override switch controls the speed of the movements (I believe there are 3, maybe 4 settings, 100%, 75%, 50 and 25% type of thing) when it's in manual "jog" mode but doesn't have any affect on rapids during a program cycle (G00 moves)
    On another, older machine he has that is running an older version of the control (not 1000. I think it was 20 or 40) the override switch works as I believe it should by limiting the speed in both manual and program modes.
    Before I get into the wiring I was hoping there might be a parameter somewhere (There is the T0 and T1 in settings screen but really that just seems to turn off the switch all together)
    Thanks for any help
    M
    Aug 2009
    1573
    Re: Delta 1000 Rapid override
    ...MODE SELECT> 5(SETUP). TM2 or TM4 Enter should enable Rapid Overide
    DJ
    Jan 2007
    311
    Thanks I'll try that.
    (that should allow the switch to slow down rapids during programed moves like I think it should right?)
    M
    Jan 2007
    311
    OK, finally made it over to see the machine in person and it's not what I thought. I think I'd better start a new thread with a better title
    M
  1. Rapid Override?
    By zman300 in forum Fanuc
    Last Post: 02-04-2022, 08:06 PM
  2. is it possible to override rapid feed ?
    By deadlykitten in forum Okuma
    Last Post: 07-23-2019, 03:52 PM
  3. Rapid override
    By MSGMachine in forum Haas Mills
    Last Post: 03-28-2011, 01:22 PM
  4. fanuc rapid override
    By sdb7311 in forum Mori Seiki lathes
    Last Post: 10-21-2009, 07:55 AM
  5. RAPID OVERRIDE
    By CNC_BOB in forum OKK
    Last Post: 06-02-2008, 11:34 AM
