585,578 active members*
4,245 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Need advice! Biesse error code PLC 9000 during toolchange.
    Question Need advice! Biesse error code PLC 9000 during toolchange.
    I have a Rover S1.30 and have recently bought new tool holders. We just recently purchased the machine and had to cycle/clean the electrospindle a bit to get it moving fluidly. Now, after installing the new carousel arms and toolholders. The machine can pickup at a perfectly level point but when it goes back to drop the tool off in the carousel, we get an error. The first two are due to Incorrect air pressure and Low air pressure for the cone closing. After these, we get a PLC 9000 Machine data reading error.
    I have checked all sensors, all loading points. I have checked all air pressures, adjusted each to nominal ranges. The tool locking sensor has been jumpered to allow the electrospindle to bypass the sensor controlled by the air flow gauges. Nothing is working. Any ideas?
    Aug 2021
    5
    Re: Need advice! Biesse error code PLC 9000 during toolchange.
    What kind of Error msg?
    You can find it with log analyzer program.
  1. G20/21 error 9000 parameters? 21-M
    By Se5a in forum Fanuc
    Last Post: 11-07-2020, 07:12 PM
  2. Biesse 335, Error code S03049
    By Blabla in forum Biesse
    Last Post: 04-26-2011, 04:11 PM
  3. HURCO MB1 TOOLCHANGE ERROR
    By bkstout in forum DNC Problems and Solutions
    Last Post: 02-15-2009, 02:26 AM
