585,759 active members*
4,238 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Post processor creating incorrectly dimensioned parts?
    Mar 2021
    Cool Post processor creating incorrectly dimensioned parts?
    Hi Everyone,
    Not sure if anyone has any suggestions on this but this is becoming a real head scratcher!
    Currently, I run files through two different CAM set ups. Vcarve pro and SwoodCAM for Solidworks, Each software has its own Post Processor. If I create two files the same, one modelled in Solidworks and the other simply drawn as a 2D Vector, it results in two components of varying sizes.
    See the attached images for reference. Vcarve its cutting things perfectly whilst SwoodCAM tends to cut everything approx 0.5mm over on the X-axis and 1mm on the Y-axis.
    Is it possible for the PP to affect the final dimension of cut parts?
    any help, or pushing in the right direction on this would be greatly appreciated!
    Re: Post processor creating incorrectly dimensioned parts?
    Is one climb cutting and one conventional? That'll give you different sized parts.
    I wouldn't expect the post processor to be the issue. Not familiar with SwoodCAM, but Vectrics post processor won't have any effect on size, unless it limits the number of decimal places and you get rounding errors.
    Mar 2021
    Hi Gerry,
    Thanks - that is interesting! each path was indeed running in the different direction. Currently in the process of running some tests to see if that changes things.
    Out of interest why would climb vs conventional create differently dimensioned parts?
    Many thanks,
  1. Replies: 1
    Last Post: 11-30-2018, 04:15 PM
  2. creating additional post processor on sharpcam
    By davebruar72 in forum Uncategorised CAM Discussion
    Last Post: 11-17-2016, 08:18 PM
  3. machine makes the model incorrectly
    By gifest in forum Chinese Machines
    Last Post: 07-22-2014, 12:42 PM
  4. Creating post processor
    By kickinger in forum Postprocessor for CAM
    Last Post: 09-19-2008, 07:20 PM
  5. Editing or creating post processor in v21
    By bashcan in forum BobCad-Cam
    Last Post: 03-15-2008, 05:34 PM
