585,759 active members*
3,889 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > LOOKING FOR HEAVY DUTY CNC VERTICAL MILL
    Mar 2021
    6
    Exclamation LOOKING FOR HEAVY DUTY CNC VERTICAL MILL
    Hello All,
    I am very new to the CNC milling world, and i need some help locating a piece of equipment that will fit my needs. We will be milling pockets in 2"x7"x187" flat bar. I am in need of something that is CNC that uses somewhat updated systems and can handel that size of material.
    that weight on it will be about 700LBS. We are a fab shop so i do have the ability to make tables with rollers to help accomidate the weight. Need something that can be used heavily. Any recommendations are greatly appriciated.
    Thank You in advance,
    Josh Parker
    AMFI
    Mar 2021
    6
    Question Re: LOOKING FOR HEAVY DUTY CNC VERTICAL MILL
    for anyone interested this it the kind of work we are doing. weight is a bout 700LBS
    Attached Files Attached Files
  1. Replies: 0
    Last Post: 11-11-2013, 04:07 PM
  2. Belt Drives on a heavy-duty benchtop CNC Mill?
    By JMcDonald in forum Linear and Rotary Motion
    Last Post: 09-26-2007, 04:25 AM
  3. Converting Heavy Duty Drill Press to Mill: Help!
    By CROSSHATCH in forum Mechanical Calculations/Engineering Design
    Last Post: 09-13-2006, 03:45 AM
