585,602 active members*
3,615 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Induction Motor is it a Pinion Drive?
Results 1 to 5 of 5
    Jun 2013
    443
    I have an old 3 phase 90w induction motor. Can't remember what it came off. But it's got a twisted pinion shaft that I expect goes into a reduction gearbox.
    I want to use it for a drive on a machine but don't have a gearbox just a pinion shaft.
    Question. Is there a pulley or sprocket that is available for a shaft like this? I've had a pretty good look on the net and can't seem to find anything. My only other alternative is to make something custom. It doesn't need to be perfect or hold a lot of torque. Just drive.
    Anyone have a suggestion or know about these?
    Sent from my SM-N970F using Tapatalk
    Jan 2018
    1516
    Re: Induction Motor is it a Pinion Drive?
    Quote Originally Posted by boydage View Post
    Is it like a normal pinion shaft with a keyway? If so, what diameter?.
    If the above is the case then you could look at taperlock bush & pulley combos if they have a bush in your size.
    I recently got a 19mm bore taper bush and 112mm taperlock pulley to fit my servo.
    Jun 2013
    443
    No mate. It's one of these. I could gash something untidy together but it would be good to get something proper. I only know a reduction gearbox that might marry but I don't want to buy one and don't need it reduced in speed.Attachment 462126
    Dec 2013
    5717
    That is the pinion gear built into the motor shaft. There is no stock component that will convert directly to a pulley type drive. A clamp type drive coupling should grab onto the shaft, you are just going to have to build something.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2013
    443
    Hi Jim is that a fact. Ok. I will make something for it. I did see a split sprocket actually that looked like a solution. Off the motor its high rpm low torque required.
    Cheers
  1. Replies: 19
    Last Post: 12-19-2017, 01:43 AM
  2. Replies: 3
    Last Post: 05-05-2015, 04:16 PM
  3. 12 tooth pinion direct drive 1/8 micro step Whats my steps per inch???? motor tuning
    By greenjeens in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-26-2013, 01:50 PM
  4. Induction motor
    By HorridHenry in forum CNC Machine Related Electronics
    Last Post: 02-22-2012, 03:26 AM
  5. AC induction motor
    By Joe Weldor in forum CNC Machine Related Electronics
    Last Post: 02-19-2011, 07:26 PM
