585,722 active members*
4,482 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > need help 2000 axis interlock alarm on super max v65a with fanuc om control
    Jan 2020
    9
    Post need help 2000 axis interlock alarm on super max v65a with fanuc om control
    Hello All
    i have a machining center of supermax v65a with fanuc omd control and the parameters was lost i have re enter the parameters and diagnostics now no alarm on the screen but when i operate the axis on jog mode the alarm comes that 2000 axis interlock but when i do diagnostic 494 bit 7 o 1 then axis move goes to zero return also but when i power off and on the machines then axis interlock comes on again and also tool clamp and unclamp button is not working but clamp switch light is on but tool clamp and unclamp is not working can you help me in this i shall be thanks full to you
    Jan 2022
    7
    Re: need help 2000 axis interlock alarm on super max v65a with fanuc om control
    ME PASA IGUAL NO RESOLBISTE EL PROBLEMA
    Nov 2007
    352
    Did you power on manchine while doing a P cancel and let it find the limit switches ?
    Jan 2022
    7
    Quote Originally Posted by lshingleton View Post
    ya lo intente y no funciona
  1. 2000 axis interlock alarm fanuc om
    By Braided1122 in forum CNC Machining Centres
    Last Post: 05-16-2022, 03:08 PM
  2. Replies: 18
    Last Post: 05-13-2022, 07:00 PM
  3. Fanuc OM w/ no. 2000 axis interlock alarm
    By bikebasher in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-10-2022, 05:38 PM
