585,875 active members*
4,084 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Retrofit alternatives for Fanuc 0-M mill.
Results 1 to 7 of 7
    Dec 2014
    15
    Hi!
    I have a mill (from 1991) with fanuc 0-m control and red cap servos.
    I'm playing with the idea of installing some newer control hardware and software. Really like the Centroid system.
    I understand the red cap servos has a difficult encoder signal, but I've found some "adapter" boards (pico systems http://pico-systems.com/osc2.5/catalog/product_info.php?products_id=16&osCsid=fkvucevi7oj dcvn1v7gali16e6) that can translate it into a more universal hall system.
    But for the voltage, what kind of power supply will be needed for drivers and brakes?
    Anyone done something similar?
    Dec 2013
    5717
    Re: Retrofit alternatives for Fanuc 0-M mill.
    The motors are most likely 200V (240V) thus the drives would need to be rated the same. The brakes are most likely 24VDC, most likely only on the Z axis.
    The simple way to do this is to just replace the motors and drives with off-the-shelf units from DMM Tech or Delta. This is what I did after looking at all the options, least amount of hassle and it just works.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2014
    15
    Does dmm or delta have something bolt on?
    Dec 2013
    5717
    The DMM and Delta motors are standard sizes as are the Fanuc, so most likely they will be a bolt on in whatever power range you need. On my lathe, I had to build an adapter for the Z axis, but the other 3 were direct bolt on when I replaced the Fanuc motors. I used DMM motors and am very happy with them.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2014
    15
    Ok!
    If I'm going down that route, only the ATC will be the biggest challenge then.
    Dec 2013
    5717
    The ATC motor is most likely a standard frame size also.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2014
    15
    Thanks for your input Jim! Will def check it out!
    I'm travelling for work, and after work, my head starts making plans for the cnc at home
  1. Tormach FANUC Conversion/Retrofit using a FANUC Oi.
    By gbowne1 in forum Tormach Personal CNC Mill
    Last Post: 04-27-2021, 08:32 PM
  2. Replies: 3
    Last Post: 11-17-2018, 05:43 AM
  3. alternatives to a DRO Sherline Mill (looking for robustness)
    By runcyclexcski in forum Benchtop Machines
    Last Post: 10-30-2018, 05:26 PM
  4. Fanuc equipped CNC knee mill retrofit with Centroid Allin1DC
    By cnckeith in forum Centroid CNC Control Products
    Last Post: 05-10-2017, 10:35 PM
  5. Looking to retrofit a Mill
    By the_0utsid in forum Community Club House
    Last Post: 11-15-2005, 09:07 AM
