586,005 active members*
5,139 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Getting the motors moving on a new Avid machine
Results 1 to 3 of 3
    Mar 2019
    5
    I just finished putting together an Avid CNC PRO4848 with their plug & play NEMA 23 kit. For some reason, the motors aren't moving. Mach 4 can see the proximity switches when I put a screwdriver in front of them, and when I click the jog arrows or press the keyboard arrows or try homing, the numbers change in Mach 4, but none of the motors do anything. The motor enable switch on the box is set to Enable, and AFAIK all the motors are connected correctly. Am I missing something simple? From what I've seen, it's just supposed to work at this point.
    Jun 2013
    88
    Re: Getting the motors moving on a new Avid machine
    I would reach out the the Avid CNC Support Team, they will setup a phone or video call to troubleshoot the issue.
    Mar 2019
    5
    Thanks, I'm all set after a quick video call with the support team.
  1. Replies: 2
    Last Post: 01-08-2020, 08:33 PM
  2. problem motors not moving
    By rick027 in forum Automation Technology Products
    Last Post: 10-03-2019, 12:30 PM
  3. Motors not moving
    By neric in forum DIY CNC Router Table Machines
    Last Post: 07-27-2010, 10:58 AM
  4. Mach3 not moving motors
    By jasper371 in forum Mach Mill
    Last Post: 06-15-2009, 10:32 PM
  5. Motors not moving
    By lamicron in forum Mach Mill
    Last Post: 05-20-2008, 01:54 AM
