585,971 active members*
3,931 visitors online*
    Mar 2021
    5 Axis calibration in CAM or MACH3?
    Hello community,
    A simple question drives me crazy. Need to upgrade to 5 axis and planning to buy a cheep chinese A-B-axis (https://de.aliexpress.com/item/32827...B&gclsrc=aw.ds)
    My problem: 5 axis milling will work only, if the geometry of the 5 axis are known. But where do I enter the geometry?
    Or do you place the coordinate origin in the CAM at the intersection of the two rotational axis and assuming that the A axis is by default aligned with the x-axis?
    Thankful for helping me out!
    PS: I am familiar with Solidworks; for CAM I use Fusion360 and my Optimum BF30 is controlled by mach3. Upgrade to Ethernet smooth stepper planed for 5 axis; and it is more for drilling and not milling, so I do not need a stiff rotation axis for the moment.
    Apr 2004
    5737
    Re: 5 Axis calibration in CAM or MACH3?
    You have to set up the kinematics in your CAM program to mirror the way the machine is set up. There's no one way to do it. Mach3 has some ability to define extra axes, but there's probably a place in Fusion to do more of that. perhaps in the post-processor.
    Andrew Werby
    Website
  1. A-axis Mach3 PP with Fusion 360 new CAM rotation function
    By chrisdu in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2020, 05:18 PM
  2. Mach3 XYZ Axis Calibration
    By aliqamar in forum Calibration / Measurement
    Last Post: 02-29-2016, 09:19 AM
  3. Which CAM software for 4 axis and mach3 support ?
    By greg2fs in forum Uncategorised CAM Discussion
    Last Post: 04-18-2014, 02:55 PM
  4. A Axis Mach3 Angle Calibration
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 09-19-2010, 01:58 AM
