585,971 active members*
4,289 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Distribution of transmission from stepper motor to 2sets with 2 pressure rollers
Results 1 to 2 of 2
    Hi, I'm new to this forum. But I need help. The are 2 sets of 2" in dia. rubber wheels which supposed to push or Pull at speed 6"-80" per second plastic tubing 3/8" in dia. The linear force of the action is 18Lb to 25Lb. Imagine a square about 5" and each corner has an axle with 2" dia. rubber wheel countered to shape of 3/8" tubing. I think 34NEMA stepper with pick 1094oz per inch and continues 300oz per inch will be enough to drive all 4 wheels with set of about 2" spur gears. Motor in the center with 2" spur gear and from both side 2 axles for same 2" gears. That taken care for lower 2 pressure wheels. 2 Upper wheels have to rotate opposite direction to lower wheels. So, on motor shaft after first 2" gear is going to be 1" spur gear which will be in contact with 2 other spur gears 2" dia for Upper set of rubber pressure wheels. Now, my Question is: 1. Is it right way to distribute the torque?? 2. Any other suggestions ?? Photo attached shows the sets of rubberized wheels. Thanks for Help
    Dec 2013
    5717
    Re: Distribution of transmission from stepper motor to 2sets with 2 pressure rollers
    Consider using a timing belt to drive the lower wheels only. Let the upper wheels freewheel, held down by adjustable spring pressure and use a lever system to raise them for loading the tube.
    Here is something similar that I did to feed a flat strip
    Jim Dawson
    Sandy, Oregon, USA
  1. #179 Low Transmission Oil Pressure Fault on HAAS VF4
    By ThomaSkod in forum Haas Mills
    Last Post: 11-26-2018, 11:55 AM
  2. THE Stepper Driver and THE Distribution Board
    By NorDevX in forum News Announcements
    Last Post: 09-13-2013, 03:07 AM
  3. Replies: 2
    Last Post: 07-19-2012, 02:36 PM
  4. Stepper motor as pressure sensor
    By Akros in forum CNC Machine Related Electronics
    Last Post: 02-13-2010, 12:09 AM
  5. New Transmission Air Pressure Switch
    By Rcky123 in forum Haas Mills
    Last Post: 05-05-2007, 07:11 PM
