585,743 active members*
5,146 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Need some advice on a more efficient finish pass
    May 2013
    160
    I'm trying to find a faster method for my finish pass on this piece.
    I'm working with 6061 Aluminum
    Machining on a Haas Super Mini Mill ( with high speed machining )
    The cavity I'm finishing is a 2 inch perfectly round cavity ( see screen shot)
    I'm using a 1/4" ball end mill.
    The issue I'm having is that the machine appears to be running slower than normal on the feed rate trying to machine the curvatures on the inside walls. ( It's almost like the machine is trying to micro-manage all of the curved detail on that inside wall.
    I'm using the 3d Contour for my finish path.
    Any suggestions would be appreciated...
    On a side note after I posted this I was looking at my screen shots and I noticed I had my tolerance set fairly high ( set at .0004 ) .... could that be my problem?
    Thanks,
    Kent
    Attachment 461338
    Attachment 461340
    Attachment 461342
    Attachment 461344
    Nov 2014
    724
    Re: Need some advice on a more efficient finish pass
    Turn Smoothing on and see what you get. That'll probably help a lot.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    May 2013
    160
    Thank You Very Much Dave !
    I just tried a test one with the smoothing turned on and that fixed the issue BIG TIME!
    Now that milling head is moving smooth...and FAST....
    Prior to turning on the smoothing It took 90 minutes to machine this 5 cavity piece , and this will cut the machining time down to a total of 10 minutes. Plus it produced a much cleaner surface finish.
    I did back my tolerance setting back to .001 ( was set a .0001 )
    I set my smoothing to .001
    Thanks again.....
    Kent
    Nov 2014
    724
    Excellent - glad it worked for you!
    David
    David
    Romans 3:23
  1. Cut2D Finish pass
    By FannBlade in forum Cut2D / Cut3D
    Last Post: 11-07-2013, 02:55 PM
  2. How to chamfer/finish pass
    By wildwhl in forum CamBam
    Last Post: 10-09-2012, 01:49 PM
  3. Finish pass?
    By budpage in forum CamBam
    Last Post: 07-12-2011, 06:45 PM
  4. roughing and finish pass
    By dewme5 in forum GibbsCAM
    Last Post: 05-25-2011, 07:30 PM
  5. Finish Cutting pass.
    By Greg Maxwell in forum Mastercam
    Last Post: 11-21-2007, 06:10 PM
