585,956 active members*
4,560 visitors online*
    Mar 2021
    Help don't have G50 on Fanuc 6T
    I have a LeBlonde Mackino Baron 40. when I enter a G50 line it thows a010 code that G50 isn't there.
    Jun 2003
    205
    Re: Help don't have G50 on Fanuc 6T
    Fanuc has multiple "systems" for G code. The most common is System A but your control could be using System B or C.
    Try G92 ... works the same as G50. If it works ... you could run into other G code issues and you should investigate Systems B and C ... they are listed in the manual.
    Hope this helps.
    Check out our Real World CNC and machine shop software at Kentech Inc. - Creators of Kipware® Real World Machine Shop Software | Kentech Inc.
    - - - Updated - - -
    Nov 2007
    352
    G50 on the ^T and M was used for Work cordinate or Tool Geometric on a lathe if the Offsett screen dint have it
    First line in lathe programs used to be
    Goo G90 G50 T0101 X100.0 Z50.0
    On New controls and some updated ones G50 was used for Spindle cap as in G50 S2000 for max Rpm at that position
    Mar 2021
    ok I'll give that a try thanks
