585,582 active members*
4,582 visitors online*
Results 1 to 2 of 2
    Jan 2014
    22
    UB1 from CNCDrive power up issue
    Hello all,
    I have a UCCNC U300ETH UB1 combo running on my CNC for several years.
    Everything runs very well with the exception of one thing.
    On power up, sometimes, the UB1 is in a strange state until the UCCNC software is started.
    All lights on the board are lit up and the relays are energized. This causes my VFD to energize the spindle.
    Once UCCNC has started, the spindle stops again and everything works as it should.
    I know I could put a relay on the charge pump output to kill power to the VFD, but I'm not sure if that pin output is functioning properly in this weird state either.
    Anyone else experienced this strange behaviour?? Anyone know if there is a solution?
    Cheers!
    Jan 2018
    1516
    Re: UB1 from CNCDrive power up issue
    If it's all working fine when on, I would just try having the e-stop engaged while firing it all up until uccnc is in control.
  1. CNCdrive is Garbage
    By mrogowski in forum Servo Motors / Drives
    Last Post: 04-26-2018, 03:17 AM
  2. 300ETH UB1 power up
    By messages4alex in forum UCCNC Control Software
    Last Post: 12-18-2017, 06:02 PM
  3. Incoming Power Issue, or Transistor Issue
    By barchdesigns in forum CNC Machine Related Electronics
    Last Post: 08-19-2016, 10:32 PM
  4. Anyone using CNCdrive parts???
    By angaeng in forum Servo Motors / Drives
    Last Post: 12-20-2015, 08:24 PM
  5. CNCdrive servodrives
    By dubble in forum News Announcements
    Last Post: 01-02-2008, 05:15 PM
