Hi I have got a 762Sbb crown I can’t lock the spindle the machine doesn’t have live tooling and writing M19 doesn’t work with either chuck open or close ..
I am wondering there is a way??
I need to do this to open the back plate
M3 S0?
ahm ... normally when opening back plate the machine should be off? Isn't it?
If under power G00 C100.0 and use m code for spindle clamping if it has it
