585,737 active members*
4,773 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma lathe grooving program
    Apr 2021
    I need help programming a groove for okuma lathe to 3.0" Dia .325 in Z direction sarting @ 4.0 " DIA stock.
    Anyone please?
    Apr 2009
    1262
    Re: Okuma lathe grooving program
    G00 X4.1 Z2.325 S500M3 T010101
    G73 X3 Z2 K.1 F.003 D.1L.1
    G00 X20Z20
    Experience is what you get just after you needed it.
    Mar 2009
    1982
    there is also possibility to change the tool offset number in the grooving cycle in order to get both edges accuratelly. Sure, the grooving tool must have two offsets set up in the tool description.
    Jun 2015
    4154
    hy dsandovalm check this out :
    Code:
        NOEX LINK = 8 V1 = 123 V2 = 0.075 V3 = 0.5 ( tvf chamfer)
        G00 X500       Z300                      ( home )
        T+LINK*101 G97 S+V1*320/55 M03 M08 M42   ( index rpm coolant )
            X100       Z-10                      ( rapid way above part, at target z )
            X60+2*2.5                            ( rapid at clearance )
        G01 X60-2*V3-1             F+V2 G95      ( cut a bit under chamfer end point )
        G00 X60+2*2.5                            ( x+ )
                       Z-10+2.5+V3               ( z+ )
        G01 X60-2*V3   Z-10        F+V2*1.25     ( 45*, feed a bit faster )
            X55                    F+V2          ( restore feed )
            X55.5                                ( break chip )
            X50
        G04                        F+60/V1*0.75  ( dwell for smooth finish )
            X50.3                                ( disengage cutting edge )
        G00 X60+2*2.5                            ( rapid at clearance )
            X500        Z300 T+LINK*100          ( home )
    included so far :
    ... increased clearance approach ( good to avoid chips that are arround the part, and/or when rapids are not interpolated )
    ... mapped feeds ( go home sooner ? )
    ... parameterized chamfer ( for fine tuning )
    ... modulated ccs ( don't wave the spindle for short x travels )
    future develop directions :
    ... rad comp
    ... 2nd offset & 2nd chamfer
    ... chamfering angle <> 45*
    ... chamfer or fillet
    ... ctr & custom parameters, linked to tool offset page or variables
    ... custom roughing and finishing toolpath
    ... monitoring available from above 4mm width
    ... custom shape
    ... etc etc etc / kindly
