540,315 active members*
1,014 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > Proximity switch Mach 3 Ess Smooth stepper
Results 1 to 2 of 2
    Apr 2019
    I just replaced mechanical touch switches with Proximity switches and when triggered the led at the switch lights up but the diagnostic page in Mach does not trigger. 5v 12mm switch 4mm activation distance 300 mA Voltage on signal wire is 4.75V at rest and 2.5v triggered. I am thinking the differential is not far enough apart , especially on the low end. This morning I read about an ESS data Monitoring screen. Where would i find this and is it a fix to show the signal.? Please help , I am manually homing the machine and running without switches and would prefer otherwise. Thanks in advance
    Registered
    Nov 2012
    1068
    Re: Proximity switch Mach 3 Ess Smooth stepper
    What kind of a breakout board are you using? Does it have pull-up resistors on the inputs? If so, what is the resistor value and the rail voltage?
  1. Pokeys vs ess smooth stepper
    By Michael82 in forum SmoothStepper Motion Control
    Last Post: 04-01-2020, 10:45 PM
  2. Mach3 - ESS smooth stepper - Huanyang Chinese VFD - Mach 3 e-stopping???
    By Chris D in forum Mach Software (ArtSoft software)
    Last Post: 05-29-2019, 11:59 PM
  3. Smooth Stepper (ESS) used - $115
    By CL_MotoTech in forum Ebay Ads here
    Last Post: 05-03-2018, 01:32 PM
  4. ESS Smooth stepper communications
    By TTalma in forum SmoothStepper Motion Control
    Last Post: 03-14-2018, 06:51 AM
  5. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
