585,568 active members*
3,233 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Z Axis Ball Screw and all around maintenance
    I have a Tree J325 that has been having some Z axis issues - I took the side cover off to inspect the z axis ball screw and there was a plastic ring on the screw.Attachment 461466 I'm thinking it comes from the gap near the top.
    To the heart of the question is this part available to replace? I am going to do a round of maintenance that will include new balls for all the lead screws but is there anything else required?
    Does anyone have a mechanical diagram of the z axis ball screw?
    Oct 2017
    27
    Re: Z Axis Ball Screw and all around maintenance
    That looks like the ballscrew seal. It should not be floating. I have the J425 drawings, they should be very similar.
    I spoke with Bob at ZPS and he told me there is a set screw (that I probably can't get to) so clean and glue in place. The item is not sold by itself. So for now I've pushed it up as far I can and will monitor. It does not seem that it is causing any z-axis issues but I am having to go back and review where my problems are coming from...and I have many...The machine is NOT reliable so it's one step at a time.
  1. Replies: 4
    Last Post: 11-09-2020, 09:11 PM
  2. Ball screw maintenance
    By NicMarsha11 in forum Linear and Rotary Motion
    Last Post: 09-20-2020, 04:11 PM
  3. Do I need a new Z Axis Ball Screw?
    By KennethC in forum BallScrew Repair
    Last Post: 02-20-2016, 10:39 AM
  4. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  5. y axis ball screw
    By wayneswagon in forum Fadal
    Last Post: 03-06-2010, 04:54 PM
