585,938 active members*
3,121 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Grizzly G0720R / SX4 Won't Start - Wiring Problems?
    Apr 2004
    9
    I'm trying to wire up my Grizzly G0720R that's been disassembled for a few years and I can't get it to work correctly. I wired everything up according to the instruction manual, but it has a couple of problems:
    1. The LCD turns on and always displays "Forward" and "Stop". I can't get it to turn the spindle on. Hitting the Start button seems to do nothing.
    2. The elevation motor begins spinning as soon as I turn the machine on. Since I'm doing a CNC conversion I don't need it, but it does seem strange that the motor (which is wired up but sitting beside the machine) wants to turn for no apparent reason. If I hit the "up" button the motor will stop until I release the button.
    Reading a manual for a similar SX4 clone, it says that you can't mill while the elevation motor is moving, so maybe the spindle won't turn on for this reason. Looking at the wiring schematic, I don't see how it *wouldn't* do this. If you follow the path of the electricity, it feeds right to the blue wire of the motor even if no buttons are pressed.
    Here's the schematic:
    Attachment 461470
    Attachment 461472
    When you look at the part of the schematic with the Up/Down buttons, keep in mind that the top 2 terminals of the switch are not connected to each other when the button isn't pressed. The bottom 2 terminals are connected. When you press the button, this behavior reverses, with the top 2 becoming connected to each other and the bottom 2 becoming disconnected.
    Here's the button:
    Attachment 461474
    And here's the LCD:
    Attachment 461476
    Thanks for any suggestions.
    Nov 2007
    361
    Re: Grizzly G0720R / SX4 Won't Start - Wiring Problems?
    have you got this problem fixed yet? Just cam across this post ????
  1. New Grizzly G0720R
    By Spectyr in forum Benchtop Machines
    Last Post: 06-04-2013, 01:46 PM
  2. machine won't start up
    By krow in forum OKK
    Last Post: 08-25-2009, 11:04 PM
  3. Won't start up
    By fadalman in forum Fadal
    Last Post: 05-02-2007, 02:42 PM
