585,556 active members*
3,376 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Trochoidal milling with a robot in steel -> Sinumerik Run MyRobot /Direct Control
    Aug 2019
    22
    In the video below we combined Sinumerik Run MyRobot /Direct Control with a trochoidal milling strategy, all on a steel workpiece:
    Material: leg. steel (11SMn30)
    Tool: D=12mm
    Slot width: ae=12mm (full cutter diameter)
    Slot depth: ap=15mm
    The process was simulated in NX CAM Robotics together with the digital twin of the Sinumerik CNC -> VNCK.
    You can hear the milling process is stable and it is a good first step to be able to cut so deep in steel with a robot ????, more tests will follow in the future.
    https://www.youtube.com/watch?v=OoBgDEo_GAE
    Aug 2021
    Re: Trochoidal milling with a robot in steel -> Sinumerik Run MyRobot /Direct Control
    thank you for sharing. I'm very excited to follow the next process! w3schools css
