585,708 active members*
3,708 visitors online*
    Oct 2020
    4
    Relay on MK3/4DRV
    Is it possible to directly connect an 5V relay (70mA) to output 1,2 or 6?
    - Is the board capable of supplying the needed current?
    - Do I need to protect the output? (Fly-Back diode?)
    Martin
    Feb 2011
    138
    Re: Relay on MK3/4DRV
    I think taking an arduino single relay board with opto is good solution, there is separate power supply for it, no harm to MB
    Mar 2017
    1304
    Controller is not capable of driving relays directly.
  1. Replies: 1
    Last Post: 01-05-2020, 12:40 PM
  2. Mk3 inputs.
    By MrEmo in forum PlanetCNC
    Last Post: 01-17-2018, 04:34 PM
  3. Powering Mk3/4
    By theRat in forum PlanetCNC
    Last Post: 09-17-2017, 01:16 PM
  4. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  5. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
