585,987 active members*
4,343 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Renishaw OMP40-2 Probe Triggering
    Apr 2021
    Good morning, I apologize if this ends up in the wrong thread.....I have a Hurco VMX50 with a Renishaw probe syatem. It worked fine when i first started on this machine now it keeps giving me a error tat I cant seam to find any information on.
    "PROBE TRIGGER DETECTED WHILE JOGGING. JOG PROBE AWAY FROM PART."
    Problem is....this happens randomly while NOT jogging? Even while the probe is turned off and in the tool change magazine. I was able to get around by telling he machine no tool probe. Then turn it back on to use it. PITA but it worked till this morning....now while trying to run a probe cycle it stops and says unexpected trigger....but the probe never contacts anything? Would like to resolve this so I can get the efficiency from the probe its meant to provide.
    Huge thanks to any input!
    Apr 2021
    Quote Originally Posted by Jswingle13 View Post
    Good morning,
    My names Andy and I am a customer support engineer for Renishaw in the UK. What other systems do you have on the machine? I.e. toolsetter. It sounds like something could be interfering with the probe signal. Are you using iso or conversational programming?
    Look forward to your reply,
    Kind regards,
    Andy
    Apr 2021
    Re: Renishaw OMP40-2 Probe Triggering
    Good morning Andy, thanks for the reply....I do also have the NC4 tool setter. I use Gibbscam for programming.
