585,743 active members*
4,837 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    May 2020
    70
    Re: Remaining distance
    thank you,
    Everything is OK and responsive as often.
    I will have a few more settings window behavior questions a bit later.
    Have a nice week end
  2. #22
    May 2020
    70
    However, I just discovered a problem with the latest version.
    When I updated the app, everything worked fine. On the other hand after having switched off and then on again the Cn and the PC, I now have a licensing problem with my MK3 card.
    When I go to parameter, TNG tells me a serial number 4459 while my card should have the number 10212.
    What's going on?
  3. #23
    Mar 2017
    1304
    This issue is not related to software. Please contact our support email to resolve this.
  4. #24
    Jan 2015
    Hello,
    related to this: can someone explain what the coordinates in the "Operator" are meant for?
    I was quite confused while testing the software the first time, but after a lot of trying around, to me it seems that the coordinates shown in this tab do not affect in any way the reference coordinate systems (G54, G55 and so on), nor the machine COS nor the work COS.
    Is that correct? So they are meant for "local movement" checks?
    Thanks for clarifying!
    Best regards,
    Johannes
  5. #25
    Mar 2017
    1304
    Operator panel shows distance to least measure. Or you can set/reset it by hand.
    This is mainly used when you operate machine manually by jogging and/or when you position workpiece.
  6. #26
    Jan 2015
    Great, thanks for the explanation and quick reply. Unless I set it to zero manually, it will just be tool position wrt position when I set it to zero the last time. So if I place a few G0 commands in MDI one after the other, "Opeator" will always be in the COS from last time setting it to zero (and not with respect to last G0-command). Ok
  7. #27
    Mar 2017
    1304
    This is true for red numbers. Blue numbers show remaining distance for executing line.
Page 2 of 2 12
  1. Okuma G04 dwell time remaining display
    By jjjearls in forum Okuma
    Last Post: 01-28-2021, 05:06 PM
  2. Replies: 3
    Last Post: 10-20-2014, 02:21 PM
  3. Distance rings?
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 05-30-2012, 02:46 AM
  4. Distance Counter
    By jcambra in forum Mach Mill
    Last Post: 04-16-2009, 07:43 AM
