585,722 active members*
4,039 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB15 tailstock advancing issue..
    Feb 2021
    38
    Any ideas I cannot got my tailstock to move out on my 1990s Okuma lb15 with the peddles. Don't know if there is a command to input or unlock. Petals, cord switches all check out it just doesn't advance. I reversed the switches and it moves out. I checked the original switch and it to works. Wondering is its possibly in the board? Maybe a fuse? If so can you pull the board to change the fuse without losing all data. I do not have a back up made or know how at this point. Help greatly appreciated.
    Apr 2009
    1262
    Re: Okuma LB15 tailstock advancing issue..
    Have you switched it on in parameter mode? Chucking work/ center work on the same page as your OD/ID chucking. SET to center work.
    Experience is what you get just after you needed it.
    Nov 2007
    352
    Use M codes through MDI and takes out issue of Pedals
    Feb 2021
    38
    Thanks for the reply.. Question is where and what do I change...
    - - - Updated - - -
    Question... What are the M codes...
    Apr 2009
    1262
    Like I said go to Parameters. I think you only item down 1 page and you will see a diagram showing chucking and center pictures along with the registers for changing from OD to ID chucking and from Chucking work to Center work.
    similar to this on the newer controls:
    M55 retract tailstock
    M56 advance
  1. Okuma LB15 Gearing change issue
    By Fireater in forum Machinery Manuals / Brochures
    Last Post: 04-05-2021, 07:49 PM
  2. Okuma LB15 bubble memory issue?
    By cmcraeslo in forum Okuma
    Last Post: 05-29-2020, 06:46 PM
  3. LB15 TailStock
    By E300 in forum Okuma
    Last Post: 11-25-2014, 03:19 AM
  4. okuma lb15 tailstock elevation alignment
    By jz25180 in forum Okuma
    Last Post: 10-07-2012, 02:48 PM
  5. Okuma LB15 tailstock alignment
    By emfgllc in forum Okuma
    Last Post: 05-23-2009, 12:06 AM
