585,763 active members*
4,236 visitors online*
    Apr 2021
    9
    I need help to speed and feed rate……. In MDF
    Hi everyone
    I would like ask for help about spindle speed, feed rate, plunge rate and step down (mm/min).
    I'm only going to work in MDF, the shops selling those bits don’t know the rates.
    Cleaning bottom bits are 10, 15, 18, 22, 25, 30, 58 mm in diameter
    Needle tip rounder bits are 6, 8, 10, 12, 15, 16, 18, 22, 25, 32 mm in diameter
    V-Groove are 22mm-90°, 22mm-120°, 32mm-60°, 32mm-150°, 16mm-60° mm in diameter and angle
    Round bits are 6, 8, 10, 12, 16, 18, 22, 25, 32 mm in diameter
    Bowl is 45 mm in diameter
    1218
    Re: I need help to speed and feed rate……. In MDF
    The answer is "it depends"-you provide no information about the machine that will be used and a cheap 3018 machine from ebay won't be able to run at the same rate as a large industrial machine.Take a look at this page https://www.shopbottools.com/ShopBot...sandSpeeds.pdf .There are others out there if you search for them and they will all give a starting point from which you may decide to experiment in any direction that seems interesting.
    Apr 2021
    9
    It is a 4'x8' foot Chinese router, 6kw air spindle and servomotor
    Apr 2021
    9
    I do not really find anything on those shapes on feed and speed, especially the round shapes I find nothing and what should feed and speed be increased by with larger diameter.
    1218
  1. mdf cutting feed rate question
    By merlinhawker in forum WoodWorking Topics
    Last Post: 02-01-2013, 05:48 PM
  2. Motor Speed and Feed Rate
    By arudson in forum Mach Mill
    Last Post: 05-27-2012, 02:41 PM
  3. Routing MDF, feed rate, tool life
    By balsaman in forum DIY CNC Router Table Machines
    Last Post: 07-28-2010, 07:46 PM
  4. About feed rate and spindle speed
    By yanlo in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2009, 12:34 PM
  5. spindle speed/feed rate
    By lamed in forum MetalWork Discussion
    Last Post: 06-03-2009, 12:25 PM
