585,717 active members*
3,949 visitors online*
    Fanuc OM system hang!
    We are using Fanuc OM . From last two days the panel stops responding in between running program . When it happens the total machine stops working and panel gives no output. than we have to turn off and again turn on the machine and after 15 minutes same happened again .
    A week before machine showed a error 930 Cpu interrupt . But that error never came back till date .
    Please help us.
    Attached Thumbnails Attached Thumbnails 661D2386-2E5B-4926-828B-8AC2920D3FE8.jpg
    Sep 2009
    99
    Re: Fanuc OM system hang!
    Please check the grounding of your drives and machine- this can sometimes be an issue and the noise from the high power panel causes the computer system to have issues.
    The CPU interrupt is usually caused by a power supply voltage issue to the best of my understanding.
    Do keep us posted if there is any development.
    Best regards
    JSS
    Thanks for your advise sir i will take a proper measures for machine grounding
    Quote Originally Posted by jaideepshinh View Post
    Best regards
    JSS
    Thanks !
    It seems like working . Not a single problem from last two days
  1. Help system data save system files Fanuc 21M
    By KINGOFCASH101 in forum Fanuc
    Last Post: 06-27-2019, 06:16 AM
  2. Fanuc system 9 loading "hang"
    By waterfall in forum Fanuc
    Last Post: 07-26-2017, 02:03 PM
  3. FANUC 9M, it's HANG.
    By ning in forum Fanuc
    Last Post: 10-12-2009, 02:46 PM
  4. Want to hang from v2xt
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 04-18-2007, 06:21 PM
  5. Post help hang up?
    By nervis1 in forum Post Processors for MC
    Last Post: 01-26-2007, 10:20 PM
