585,974 active members*
4,318 visitors online*
    Jan 2012
    57
    ball screw nut replacement
    Hi guys, the ball screw nut on my X axis makes a little clicking noise. I think its due for replacement.
    Anyone know what make/model ball screw nuts Tommy was using, or if these are details are visible on the nut itself?
    I suspect its metric but not confirmed.
    Feb 2008
    69
    Re: ball screw nut replacement
    I've noticed a lot of Chinese sellers state only to use their nuts on their screws and don't recommend using others.
    As long as the pitch is the same I can't see why it wouldn't work, but you may need to play with ball bearing size to suit.
    It's been a few years since I looked, but EBay sellers used to supply ball bearings in micron increasments.
    If there double nuts it shouldn't be to much of a problem.
    Sent from my 5007U using Tapatalk
    Jan 2012
    57
    Hi guys, I traded mail with Tommy. He said the ballscrew was 3/4" diameter and pitch of 0.5".
    He mentioned the ball nut manufacturer was Lee Linear but didn't have part numbers.
    Their website doesn't use the words "ball nut" anyplace, I'm speculating they're out of the ball screw business as my mill is from 2013.
    I'm way out of my depths and just looking to find something that will be a drop in replacement for my existing ball nut that is making clicking noises.
    I checked Lee Linear's website and there is no mention of the word "ball nut" anyplace.
    Anyone know where I can find 3/4-0.5 ball nuts?
    I found one on mcmaster-carr and it had backlash of 0.015" which makes it garbage for a CNC mill
    I get the feeling I'm completely screwed and would be better off getting a 20mm ballscrew + ball nut combo and hoping my pulleys still fit ?
    Mar 2009
    1982
    Is the clicking sound only criteria?
    what about taking measurements: accuracy, repeatability ?
    Jan 2012
    57
    Going from memory here, X-axis had something like 0.007 backlash, Y and Z were around 0.002 or less.
    I will double check the values this evening for X axis.
  1. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 09-02-2021, 07:48 PM
  2. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  3. Ball Screw nut replacement very loose!
    By Bearhawk LSA in forum Benchtop Machines
    Last Post: 10-03-2016, 04:08 PM
  4. Looking for replacement CNCFusion X3 Y-axis ball screw/nut
    By Analias in forum X3/SX3/G0619/G0463
    Last Post: 02-18-2013, 10:33 PM
  5. Big Ball Screw & Ball Nut mistake.
    By Jack F in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2006, 04:53 AM
