Re: 95 LNC 8 threading help
hy please check attached threading section from the manual
i also have re-writen your code
for smooth finish, use spring pases combined with re-cutting the crest ( using the tool before the thread ) and the chamfers ( towards the root diameter ); operations type & order, and number of repetetions, may vary, depending on threading insert and others
g33 is more powerfull than g71, since it allows better control, but coding it is a bit more demanding
i have used g33 for years, but lately i switched to g34, in order to better manage vanished treads and repositioning motions
is possible to eliminate one turret index, by cutting the chamfer also with the threading insert, using one extra offset, ... and there are others tricks as well / kindly
Code:
G50 S2000
G00 X400 z400
T040404 G97 S300 M03 M41 M08
X0.665 Z 0.04
G33 X0.6717 Z-0.59 F0.025 G95
X0.6783
X0.685
X0.685
G00 X400 Z400 M09 T0400
M02
