585,748 active members*
3,563 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Fly cutter surfacing plywood spindle speed and feeds
Results 1 to 8 of 8
    Mar 2017
    926
    What spindle speed and feeds do you guys use for surfacing a spoil-board with a fly cutter?
    I picked up these two cutters:
    They don't seem to be covered by the usual online speeds and feed calcs I use.
    Re: Fly cutter surfacing plywood spindle speed and feeds
    A flu cutter is not an appropriate tool for surfacing a spoilboard and is not safe in any router spindle, unless you can use it under 1000 rpm.
    You want something like this.
    https://www.amanatool.com/rc-2255-cn...outer-bit.html
    Or even a plane carbide tipped router bit with a large diameter.
    Mar 2017
    926
    Thanks. I've ordered a pair.
    Out of interest, is it the spindle speed that makes a fly cutter unsafe (I.e. that the carbide cutter might come loose and get launched at me) or is it the material (I.e. fire risk with wood)?
    My spindle actually can go as low as 1000 rpm (or at least the manual said it's rated for that). It's electric fan cooled but it doesn't pack much of a punch at that speed.
    Yes, you can't spin a fly cutter very fast without creating an incredible amount if vibration, and it might even come flying out of the spindle.
    You can use that Amana tool at 10,000-13,000 and 300-600ipm.
    Mar 2017
    926
    I experienced that first hand yesterday when I turned it on at 6000 rpm for a few seconds...
    My machine is 1000lb + of Epoxy granite and is usually super quiet. It sounded like a helicopter landed on it with the fly cutter in there. It was enough to make me turn it off without cutting anything.
    It was a really strange sound....
    Hopefully the Amana tools are better balanced for high speed.
    On our 10,000 lb router at work, if a small chip gets between the spindle and toolholder during a toolchange, it sounds the same way, with just the toolholder of by a few thousandths.
    Mar 2017
    926
    I remember reading about balanced tools. Now I understand the significance.
    I assume your 10,000 lb router has a far larger cutting area than mine but, if I understand right, the point is that it doesn't matter how robust a machine is. Unbalanced tools make an upsetting sound and those who ignore it could meet a grizzly end...
    The new high speed spindle appropriate surfacing tools arrive and they make a much more pleasing sound and cut.
    Thank you (again). You helped me dodge a bullet (almost literally) with this one.
  1. Replies: 1
    Last Post: 04-16-2018, 06:02 PM
  2. Replies: 5
    Last Post: 12-05-2011, 06:22 AM
  3. Which tool bit type for surfacing aluminum with a fly cutter?
    By cnczoner in forum MetalWork Discussion
    Last Post: 01-03-2008, 08:54 PM
  4. Feeds, speeds, and bits for plywood
    By sploo in forum WoodWorking Topics
    Last Post: 09-17-2007, 05:59 PM
  5. Taig Fly Cutter Feed/Speed
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-12-2007, 06:09 AM
