585,954 active members*
4,142 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > SPINDLE BEARING REPLACING - ARROW 750 EKK
    Jul 2005
    107
    Hi
    The spindle from my Arrow2 EKK 5000RPM, failed. One washer springs broke and damaged a sensor. I pulled down the spindle and now I'm trying to refurnish the spindle.
    Does any one have experince changing the angular contact bearings from the spindle. The spindle is AIR-OIL lubricated.
    The original 3 bearings set from FIVES are over $ 2000
    I have found NSK 7014CTR bearings with out the holes and grove for AIR-OIL lubrication, very cheap $320 duplex, I will buy 2 pairs; I was planning to send to some enginery company that modifie bearings, to add the grove and holes, also to make them a 3 set.
    I'm going to share the pictures of my work.
    PS: sorry for the bad english.
    Any comment is welcome.
    Jul 2005
    107
    Re: SPINDLE BEARING REPLACING - ARROW 750 EKK
    Sharing some cad drawings from some CINCINNATI SPINDLES.
    Attached Files Attached Files
    Quote Originally Posted by Chivo View Post
    Hello,
    Can you help me with the drawing for spindle number 0612624200003, or tell me if it is identical to one of the drawings you uploaded. Thank you!
  1. Arrow 2 EKK
    By Sebalj in forum Cincinnati CNC
    Last Post: 04-24-2021, 04:23 PM
  2. Cincinnati Arrow 2 500 EKK CNC VMC
    Last Post: 03-20-2021, 06:50 PM
  3. Replacing spindle bearing cartridge
    By GITRDUN in forum Haas Mills
    Last Post: 04-12-2015, 06:43 AM
  4. Arrow 750 spindle drawing?
    By coop31 in forum Cincinnati CNC
    Last Post: 01-31-2012, 01:30 PM
  5. Chaning table bearing/rails on Arrow 750
    By laka in forum Cincinnati CNC
    Last Post: 01-30-2009, 12:23 AM
