Hello all,
I'm trying to get mach 4 surface map wizard to work. My machine does the probing and I load the surface map but it doesn't make a difference. The Z axis doesn't make any sort of adjustments. I'm using ESS that came with my Avid plug and play kit (CRP800-00E-8). That wizard is really the only reason I upgraded to mach 4. I engrave on uneven surfaces. Any advice would be appreciated.
