586,022 active members*
3,638 visitors online*
Thread: PP for mach3
    Jan 2015
    80
    PP for mach3
    First, I want to thank you for takeing the time to help.. When i get my toolpath done i save it in doc's, then close vcarve and go to doc's and send it to the flashdrive. vcarve has a ton of PP listed in the drop down, which one in your opinion should i use ? Here is where i'm kinda not sure about this, is the vcarve post processor confliting with the velox mach3 software ? thanks again..
    Apr 2005
    304
    Cool Re: PP for mach3
    To make your life easier, copy the post processor that you need from C\ProgramData\Vectric\Aspire\V9.5\PostP to C\ProgramData\Vectric\Aspire\V9.5\My_PostP
    Next time when you start your software, only the post processors that are in My_PostP folder will be visible in the drop down list when generating G-code
    As you are using Mach3 as controller, use relevant Mach2_3_... post processor.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Jan 2015
    80
    Re: PP for mach3
    ok, this is going to sound dumb but not sure how to do this.. I don't see this ( relevant Mach2_3_... post processor. ) in vcarve pro PP list so if you could be awesome and tell me or give me the steps on where to get that PP and how to install it where it needs to be, I'm just learning this and its kinda info overload. I can completely restore a classic mustang and build a house and almost anything but this tech stuff is very slowly sinking in.. you guys are really something knowing how to do all this stuff so easy. thanks
    Nov 2008
    644
    Re: PP for mach3
    In my copy of vcarve I use
    Mach2/3 Arcs (mm)(*.txt).
    I’m actually using Mach4
    I also modified that pp and added a delay for spindle rpm startup.
    Jan 2015
    80
    Re: PP for mach3
    Thank you, i'll give it a try..
  1. Mach3, 2010 Screenset, Mach3, G540, UC100, Win 10 - Will not home
    By SteveS in forum Mach Software (ArtSoft software)
    Last Post: 04-25-2019, 05:49 PM
  2. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
  3. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
