586,009 active members*
4,762 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > programming blind hole radius help
    Dec 2006
    26
    Hello all.
    I am trying to mill an ID radius as seen in pics.
    I have machined a funnel using an older version of Gibbs in the past.
    I'm remembering swept side with the shape in another workgroup extruded,
    I think.
    None of that is working currently.
    Gibbs 7.3.1 2D only. XY center of part in a chuck on table. Wanted to rough with a 3/8
    Flat endmill and finish with 3/8 ball. Aluminum.
    Th
    Jan 2009
    103
    Re: programming blind hole radius help
    You can use the Spiral Plugin driven by the Geometry. You need to define the Profile in the X-Y Plane using the line and arc as if you were going to create a revolved surface or solid, then select the geometry and run the plugin. I'm not sure what version the Plugin was introduced, but it works great.
  1. Blind hole technique
    By JDona in forum Tormach Personal CNC Mill
    Last Post: 04-17-2018, 03:19 PM
  2. blind hole drilling
    By roy-ito in forum Hitachi Seikis
    Last Post: 09-30-2014, 08:56 PM
  3. Trouble tapping a blind hole
    By subi4ester in forum Haas Mills
    Last Post: 10-29-2010, 10:24 PM
  4. blind hole, custom drill
    By kendo in forum MetalWork Discussion
    Last Post: 12-09-2008, 10:40 PM
  5. Looking for small "blind hole"? clamps
    By rkremser in forum MetalWork Discussion
    Last Post: 10-08-2008, 12:23 AM
