585,722 active members*
4,103 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Projecting edges to a plane "0"
    Apr 2021
    Lightbulb Projecting edges to a plane "0"
    Hi everybody!
    I would like to create a geomatry machining range that I pulled from the edge of the part.
    Unfortunately, the geometry lies in two planes ( 4, 4-1, 4-2 ).
    I have an error when creating the scope: the element does not lie on the zero plane.
    Does any one have an idea how to project this range flat? It shoudl look like on photo 5-1 , 5-2.
    Thanks !
    Dec 2017
    34
    Re: Projecting edges to a plane "0"
    It used to be called 2d snap. If you are trying to select the edge of a model and have it come out at 0.
    Before you select any edges. look in the top left corner. There is an icon that says 2d. Click on that, then the edges you want to snap to zero.
    http://www.heavymetalcnc.com
  1. Milling in a lathe with "XC Plane-Switch" in Mach3 possible?
    By offe76 in forum Mach Software (ArtSoft software)
    Last Post: 09-14-2017, 03:04 PM
  2. Replies: 2
    Last Post: 11-16-2012, 03:17 AM
  3. What causes "rough" edges when laser cutting acrylic?
    By shobley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2011, 12:19 PM
  4. "jword given for arc in xz plane line number xxx" ???
    By HankMcSpank in forum G-Code Programing
    Last Post: 05-11-2009, 01:28 PM
