I'm building a DIY cnc but I've hit a bottleneck. I want to run my spindle with a belt and already have the motor I plan to use to drive it (Vevor 2.2kw spindle) The issue I have is I want to step down the rpm which is easy enough to do because the spindle has terrible torque below 3000rpm and I want at to run at like 600rpm or in around there for steel cutting. Here is the issue...
I can't make a spindle with the correct tolerances because I don't have a good lathe. I can't custom make one because its ridiculously expensive and I can't find where to buy one. When I google spindles, all I get is motors. I found one without a motor on aliexpress but I've had so many bad experiences with ali express I just don't trust them. I'm using either R8 or MT3 tooling, so if anyone can help me out or offer some advice please do so!
Thanks.
- David
Based in Ireland.
Some extra info/queries/jargon
I did a quote, but it was what I would consider a rough quote, so when I said it was too expensive that is just my touch feely idea. I figure the tolerances will be tight for a precision custom spindle and I actualy don't know how to express tolerances for a taper or what the tolerances should be. Machinery handbook said 0.002" or 2 thou per foot but I don't know what they mean by foot. Do I give the manufacturers a tolerance on the angle of the internal taper, who knows. This is hard when your an outsider. I figure if I can buy like a R8 to straight shank adpater maybe that will work but if I jam that shank into a hole with a interference fit will I lose concentricity.
