585,875 active members*
4,110 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Jun 2017
    119
    Emergency Stop.
    Hello.
    I recently converted from CNCusbcontroller to TNG.
    In CNCUSB I used a input board for floating head switch and emergency stop. In CNCUSB you could decide what the input pins would mean. So Input pin 2 could have several different commands.
    In TNG this is not possible anymore?? Is there a way around this? Or do I have to buy another board to connect to ctrl?
    Mar 2017
    1304
    Re: Emergency Stop.
    Emergency stop has dedicated pin. Why don't you use it?
    You can also assign any input pin to be shortcut. See user manual page 328.
    Jun 2017
    119
    Re: Emergency Stop.
    Quote Originally Posted by PlanetCNC View Post
    Thanks.
    I only have 1 input board. Don't want to buy another one for just 1 input.
    Aug 2020
    131
    Re: Emergency Stop.
    why do you need a input board if you just need one pin?
    Just crimp a connector and connect it directly to the board.
    Jan 2018
    1516
    Re: Emergency Stop.
    All my emergency stop items (buttons, switches etc) are wired in series as a Normally Closed circuit going into 1 pin.
    If either one of them triggers it creates a stop condition.
    Jun 2017
    119
    Re: Emergency Stop.
    Quote Originally Posted by dazp1976 View Post
    That's how they should be. But that was not the question here.
    Problem solved.
    Jan 2016
    19
    Re: Emergency Stop.
    Hello,
    I want to use a input pin to switch emergency stop.
    The switch that I use is a NC. So when I adress the switch to E-Stop via shortcuts it is not working probably....
    Reason is that the board is waiting for a high signal - I guess.
    So when I press the button and open the circuit nothing happens. When I unlock the switch and close the circuit the E-Stop is set.
    Question: Can I change the mode of the input so it reacts on a open circuit?
    Best regards,
    Marc
    Jun 2017
    119
    Re: Emergency Stop.
    Quote Originally Posted by hoizlaender View Post
    Hello,
    Best regards,
    Marc
    My machine was configured the exact same way but it actually stopped the machine when activating from NC position. But for some reason my machine is acting the same way as yours is doing. I haven't changed any settings so this is very weird for me.
    Jan 2018
    1516
    Re: Emergency Stop.
    Hello,
    Best regards,
    Marc
    With my Mach3. Changing active low/high setting did this.
    One runs voltage through circuit and activates when stop pressed to cut voltage (NC).
    One runs zero voltage through and activates when voltage becomes present on switch press (NO).
    Is possible yours works the same.
    Can't remember which way round the low/high goes though.
    Mar 2009
    1982
    Re: Emergency Stop.
    the input reacts to high voltage either to low. Connect the input to low voltage through resistor ( 1kohm should work ) and use your EStop contacts to connect high voltage to the input.
    When Estop pressed it will be high on the input because connecte to high voltage through EStop contacts. When Estop released, the resistor ensure low voltage on the input.
    Mar 2017
    1304
    Re: Emergency Stop.
    Don't do this.
    All inputs can be inverted in settings. Just check "Invert" option.
    Jan 2018
    1516
    Re: Emergency Stop.
    Don't do this.
    Which is the equivelent to setting an input to either 'active high' or 'active low' in other programs like Mach, yes?.
    (for future reference).
    Jan 2016
    19
    Re: Emergency Stop.
    Hello,
    thank you for your response.
    I changed the setting under FIle>Settings>Input/Output
    Now I can avtivate E-Stop with pressing the button, but to deacticate E-Stop I need to switch the button a second time.
    Thats better, but still not exactly what I want and would expect.
    Best regards,
    Marc
    Jan 2018
    1516
    Re: Emergency Stop.
    Hello,
    Best regards,
    Marc
    Isn't that the point of the estop?.
    Once it's pressed it stays engaged until you physically release it. That's how they work.
    It stops prats (usually management) from trying to start a machine while you have your head buried inside it!.
    Mar 2017
    1304
    Re: Emergency Stop.
    E-Strop is usually latching button. Controller has dedicated e-stop input for it.
    Jan 2016
    19
    Re: Emergency Stop.
    Sure, I understand this. For this reason emergency buttons are normally locked in the pressed position (as mine is)
    But normaly you don´t need to press the button a second time to release E-Stop funktion.
    At the moment it works like this when E-Button is released - Circuit closed - Machine is running
    1. E-Button pressed and locked - Circiut open - Machine stopps
    2. E-Button unlocked and released - Circuit closed- Still E-Stop active at the planet-controller
    3. E-Button pressed an locked again - Circuit open - E-Stop not longer indicated controller
    4. E-Button unlocked and released - Circuit closed - E-Stop not active
    Mar 2009
    1982
    Re: Emergency Stop.
    That's not safe.
    Mar 2017
    1304
    Re: Emergency Stop.
    why don't you connect e-stop button to e-stop pin like suggested?
    Jan 2018
    1516
    You would have to reset a stop either way. Pressing a button or in the software. So basically isn't that what you seem to be doing?. It is what it is.
    Jan 2016
    19
    Re: Emergency Stop.
    You have to know that my control box is separate from the Machine and connected to a control panel (including the E-Stop) via wiring.
    I the expectation that every input can be assigned to almost any function via shortcuts I designed adapter PCBs .
    And now it would be/will be a big effort to change the wiring to link the E-button to the CTRL connector.
Page 1 of 2 12
  1. Problems with Emergency Stop/Stop function.
    By MrEmo in forum PlanetCNC
    Last Post: 10-19-2021, 10:47 AM
  2. emergency stop condition after E stop
    By Cosmin90 in forum Fadal
    Last Post: 01-14-2020, 01:30 AM
  3. Emergency Stop
    By K2Developmentab in forum Fadal
    Last Post: 08-21-2013, 01:21 PM
  4. Generic Emergency Stop (E-Stop) Design Concepts?
    By zipzit in forum CNC Machine Related Electronics
    Last Post: 06-09-2011, 12:14 PM
