586,000 active members*
4,756 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko G540 r8 and air solenoid set up
    Post Gecko G540 r8 and air solenoid set up
    I want to use a solenoid on the M7 mist function and I am not sure how to set this up.
    I have a 12v solenoid.
    I use Mach3 and UC100.
    Do I need a relay switch off pin 6 on the G540 and then to the solenoid or do I hook the solenoid directly to the G540, pin 6 and output 2?
    Any help would be appreciated.
    Nov 2008
    644
    Re: Gecko G540 r8 and air solenoid set up
    Rev4 G540 manual shows you connect one side of the DC relay coil to pin 6 and the other side of the coil to positive of the relay power supply. Negative from that PS goes to the negative motor power supply.
    So you can power the step drives (in G540) and motors up to 50 volts. But relays are normally 12 or 24 volts. That’s why there are two PS.
    Thank you, I will try this way.
    Aug 2005
    1092
    If you are running your G540 off 48V you can get relays with a 48V coil removing the need for a 2nd power supply.
    https://www.homanndesigns.com/index....products_id=88
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
  1. 6.5w air solenoid directly to g540 without relay?
    By QuinnSjoblom in forum Gecko Drives
    Last Post: 09-16-2018, 03:51 PM
  2. WTB- CNC Mini Mill with Gecko G540 set up
    By mpix00 in forum Want To Buy...Need help!
    Last Post: 03-26-2017, 07:44 PM
  3. Gecko G540 Current Set Resister
    By radensb in forum Gecko Drives
    Last Post: 12-08-2015, 12:56 AM
  4. Gecko G540 - Styre solenoid ventil
    By henrikm in forum Norwegian
    Last Post: 01-06-2015, 11:36 AM
