585,670 active members*
4,263 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree J325 Retrofit 2.0
Results 1 to 10 of 10
    I've started to order parts to do a second round retrofit. The original retrofit used a Campbell design BOB, Gecko G320 servo drives and was driven by Mach3. It worked ok but when I put it together I was not aware of most of the items that make up a complete control system. This TREE forum has opened my eyes and I hope to move toward a machine that is closer in line to the industrial grade controls that were originally there.
    So far I have ordered a Centroid Acorn with the Pro software, a mini PC, DMM 3 axis servo kit with 0.75 kw motors and DYN4 drivers. I have a list started for Automation Direct..
    Let the fun begin
    Re: Tree J325 Retrofit 2.0
    I've been spending a lot of time climbing on my mill. When I did my first retrofit there were a lot of items/wires left unconnected. Now I have gone through and identified many of the unknown/unused wires and am marking them as I plan to connect many in the upgrade. One item that NEEDS to be connected is the spindle fan - this machine saw light use over the last ten years so the motor never go very hot ...but it's there for a reason - along with the over temp wires. I started another thread asking about the pulse generator on the motor to see if it can be used.
    I've been bench testing the Acorn and trying to hook up as many items to get a better understanding of controls...still aways to go but I'm getting closer all the time.
    I have one item that I'm unsure about it's purpose - there is a pressure disconnect switch that is part of the pnuematic chain - currently disconnected and I don't see on on the Tree diagram - any ideas? It's the last item below the cabinetAttachment 463956
    Running out of room on my benchAttachment 463958
    Aug 2009
    1570
    ...maybe wire number 258 in that bird nest?
    Attached Files Attached Files
    Thanks Machinehop5. I saw wire 258 . So that device is there to monitor air pressure...with limited I/O that wire may not get connected ot I could wire in a light...
    Nov 2013
    152
    Centroid has a low pressure alarm and a low pressure shutdown input that this can be wired to.
    When I can't hear the air leaks I'll know I have low pressure, in the future I may need an Ether board. 9-)
    Oct 2017
    27
    Or when your tool comes out of the spindle due to low air pressure...
    Quote Originally Posted by dstjohn99 View Post
    If your machine releases the tool on low pressure...RUN. My tool holder won't release with low pressure.
    I've gotten the Centroid Acorn installed and as I try to hook up the VFD I'm finding that the spindle is very stiff. I'll do some further investigation but I may be taking it out to inspect the bearings. Does anyone have a part number? I can measure them when they're out but I thought some advance searching would give me an idea of the cost. I don't see anything in the Tree lubrication documents so I believe that it's not an oiling issue but potentially dirty grease. With any luck I'll find some miscellaneous string that got wound around the spindle and will be to normal...
    I removed the spindle and inspected the bearings - maybe the top bearing had too much grease, so I wiped off the excess. The spindle bearing feel fine the top bearing feels fine and I removed the pulley and that bearing feels fine. By fine I don't see any evidence of brinelling or notchy- ness they all turn smoothly. When I started the spindle was difficult to turn by hand. I am about to put it back in the see if exhibits the same behavior.
    That fricken snap ring was an expletive to get out - I'm hoping it goes in easier. I'll clean the groove prior to trying
  1. Tree J325 and dynapath delta 20
    By 85burban in forum Tree
    Last Post: 02-04-2012, 07:25 PM
  2. Tree j325 tool holders
    By MadPickinSkills in forum Tree
    Last Post: 11-21-2010, 05:56 PM
  3. Whats a Tree J325 worth?
    Last Post: 10-01-2010, 12:26 AM
  4. Tree J325 Spindle Problem
    By Frisbee in forum Tree
    Last Post: 09-29-2010, 08:18 PM
  5. Tree J325- First time start up-Help
    By J. Moran in forum Tree
    Last Post: 10-10-2009, 03:54 AM
