586,024 active members*
4,316 visitors online*
    Jan 2019
    22
    Initial ATC tool change issue
    Guys,
    I'm having an issue with my M6 macro after the initial reboot of the software. After the first attempt it works very well. Basically it moves to the correct location, lowers the spindle but then fails to trigger the Yxxx ports as configured to do so in the M6 macro to action the sliding rack, dust shoe up and the spindle chuck open etc.
    It only happens after the software restart and the tool indicator is at tool 0. Once it has a tool in place it works as planned. I've attached my macro that has been edited
    Any help would be great.
    Paul
    Attached Files Attached Files
    35538
    Re: Initial ATC tool change issue
    Edit. I think I was wrong, I'll look at it again in a little while.
    What tool are you calling with the first M6?
    35538
    If the current tool = 0, then none of these things will happen.
    if(Currenttool!=0) // No need to drop down tool if current tool number is zero
    // Move to old tool position on XY plane
    exec.Code("G00 G53 X" + ToolX[Currenttool] + " Y" + ToolY[Currenttool]);
    while(exec.IsMoving()){}
    // Drop current tool
    exec.Setoutpin(Dustopenport, Dustopenpin); // Open the Dust with pneumatic valve
    exec.Wait(3000); // Wait one 5000msec
    exec.Code("G00 G53 Z"+ Ztoolrelease); // Move Z axis down to tool holder position
    exec.Wait(2000); // Wait one 5000msec
    exec.Setoutpin(Rackopenport, Rackopenpin); // Open the Rackin with pneumatic valve
    exec.Setoutpin(Chuckopenport, Chuckopenpin); // Open the chuck with pneumatic valve
    exec.Wait(1000); // Wait one 1000msec
    exec.Code("G00 G53 Z"+ SafeZ); // Move Z up
    Jan 2019
    22
    Thanks as always for your input Gerry,
    Just depends on the cut file to be honest. Any tool from 1 to 9.
    Sent from my SM-G991B using Tapatalk
  1. TO CHANGE AN ATC SPINDLE TOOL MANUALLY
    By tdoz in forum Spindles / VFD
    Last Post: 01-20-2016, 09:07 AM
  2. Arrow 750 tool change/tool carosuel issue
    By Insept in forum Cincinnati CNC
    Last Post: 10-22-2012, 01:31 PM
  3. Tool change without ATC
    By Danijel in forum Fanuc
    Last Post: 06-02-2011, 04:34 AM
  4. Automatic Tool Change (ATC) - Help!
    By spotlite in forum Mach Wizards, Macros, & Addons
    Last Post: 05-18-2008, 11:16 AM
